Print at Sep 13, 2026, 3:25:59 PM
Posted by Daniels118 at Mar 17, 2022, 4:57:31 PM
Re: Plugins manager
Thank you for your feedback, here some observations:
1) ok, I will add it in the next release;
2) ok, I will fix it in the next release;
3) the plugin names in the list are not part of the plugin manger itself. They are downloaded from a remote repository that can be updated by me or by the plugin developer. Multilanguage is supported, but translating everything requires a lot of time. I may think of a collaborative approach, but it is a lot of work, I've no clear plans about this.
4) This happens if the installed version of the plugin isn't one in the database. The match is done using the plugin name, provider and version. If you have manually changed any of these fields within your sh3p files, then the plugin manager isn't able to recognize it. Unfortunately there is no workaround for this, unless you choose to build and mantain your own plugin repository.
You can already do this by uploading a file like this one on your own server, and changing the repository accordingly in the Plugin manager settings.
5) This could be achieved by simply copying the directory content to the SH3D plugins folder.
