Print at Aug 26, 2026, 1:38:04 AM
Posted by bernard_s at Feb 20, 2022, 9:25:18 PM
SweetHome3DJS won't compile
Hi
Brilliant system and was looking forward to running the browser version :) However:
Running ant (Windows 10) on SweetHome3DJS fails to build. It is related to tsc which it says it cannot find.
Cannot run program "C:\Users\b_s\.jsweet.v3-node_modules\tsc.cmd"
The system cannot find the file specified
The folder exists
...but tsc.cmd is instead under C:\Users\b_s\.jsweet.v3-node_modules\node_modules\.bin\
Any ideas hwo I fix it?
thanks.
Bernard
Portion of the ant log:
[java] 2022-02-20 20:11:28.028 INFO JSweetTranspiler:1227 - created tools\JSweet\build\ts\bundle.d.ts
[java] 2022-02-20 20:11:28.028 INFO JSweetTranspiler:865 - ts2js on org.jsweet.transpiler.TypeScript2JavaScriptWithTscTranspiler@b7f2c13 sourceFiles=137
[java] 2022-02-20 20:11:28.028 INFO TypeScript2JavaScriptWithTscTranspiler:84 - launching tsc...
[java] 2022-02-20 20:11:28.028 ERROR ProcessUtil:365 - Cannot run program "C:\Users\b_s\.jsweet.v3-node_modules\tsc.cmd" (in directory "tools\JSweet\build\ts"): CreateProcess error=2, The system cannot find the file specified
[java] java.io.IOException: Cannot run program "C:\Users\b_s\.jsweet.v3-node_modules\tsc.cmd" (in directory "tools\JSweet\build\ts"): CreateProcess error=2, The system cannot find the file specified
[java] at java.base/java.lang.ProcessBuilder.start(ProcessBuilder.java:1128)
[java] at java.base/java.lang.ProcessBuilder.start(ProcessBuilder.java:1071)
[java] at org.jsweet.transpiler.util.ProcessUtil.runCommand(ProcessUtil.java:317)
[java] at org.jsweet.transpiler.TypeScript2JavaScriptWithTscTranspiler.doTranspile(TypeScript2JavaScriptWithTs
cTranspiler.java:92)
[java] at org.jsweet.transpiler.TypeScript2JavaScriptTranspiler.ts2js(TypeScript2JavaScriptTranspiler.java:37)
[java] at org.jsweet.transpiler.JSweetTranspiler.ts2js(JSweetTranspiler.java:866)
[java] at org.jsweet.transpiler.JSweetTranspiler.transpile(JSweetTranspiler.java:841)
[java] at org.jsweet.JSweetCommandLineLauncher$JSweetTranspilationTask.run(JSweetCommandLineLauncher.java:897)
[java] at org.jsweet.JSweetCommandLineLauncher.transpileWithArgs(JSweetCommandLineLauncher.java:272)
[java] at org.jsweet.JSweetCommandLineLauncher.main(JSweetCommandLineLauncher.java:240)
[java] Caused by: java.io.IOException: CreateProcess error=2, The system cannot find the file specified
[java] at java.base/java.lang.ProcessImpl.create(Native Method)
[java] at java.base/java.lang.ProcessImpl.<init>(ProcessImpl.java:487)
[java] at java.base/java.lang.ProcessImpl.start(ProcessImpl.java:154)
[java] at java.base/java.lang.ProcessBuilder.start(ProcessBuilder.java:1107)
[java] ... 9 more
[java] ERROR: Unknown tsc error
[java] 2022-02-20 20:11:28.028 INFO JSweetTranspiler:849 - transpilation process finished in 23174 ms
[java] > java2ts: 19898.3957ms
[java] > ts2js: 44.0433ms
[java]
[java] INFO: transpilation failed with 1 error(s) and 0 warning(s)
BUILD FAILED
c:\sh3d\SweetHome3DJS\build.xml:81: The following error occurred while executing this line:
c:\sh3d\SweetHome3DJS\build.xml:37: Java returned: 1
Total time: 25 seconds
