Sweet Home 3D Forum » List all forums » » Forum: Developers » » » Thread: Generate roof plugin » » » » Post: Re: Generate roof plugin |
Print at Sep 24, 2026, 11:55:32 AM |
| Posted by dorin at Feb 15, 2022, 7:37:28 AM |
Re: Generate roof plugin The plugin work in this order: 1. Select 1 or more rooms. If are more only first will be computed. 2. Menu->Tool->Generate roof... Recommendation 1: try on a test file, eventually with file provided on this page. Recommendation 2: install AutoDimensioning plugin, read instructions , and, if You have some walls, will generate roof projection for that walls. NOTE 1: If roof are not generated correctly, try to modify a little bit the foot print to avoid some edges to be collinear. NOTE 2: Even so will not work all the time! PS: I've try to reproduce Your building and with v.1.0 work! Verify in Help->About Your installed version. The result are not total correct (some faces) but it work. ---------------------------------------- A computer program does what you tell it to do, not what you want it to do. Murphy's Law When all else fails, read the instructions. Murphy's Law If you don't like "AS IS", DIY. Dorin's law |
Current timezone is GMT Sep 24, 2026, 11:55:32 AM |
