Print at Aug 6, 2026, 2:35:28 AM
Posted by Daniels118 at Feb 14, 2022, 7:57:43 AM
Re: Floor have huge size in svg (tens of Mb)
Not sure why, Daniel, but it seems I'm your nemesis
AHAHAH laughing
Please check the cpu usage using the task manager while exporting to svg.
I suspect that compressing that image could be too heavy for the compression algorithm.
I was expecting there might be problems, so I figured out a way to change the default settings without rebuilding the plugin. You could try to decrease the compression level by starting sh3d with a java property named png.compression,it accepts integer values in range 0-9 (the default is 9).
