Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: Floor have huge size in svg (tens of Mb) » » » » Post: Re: Floor have huge size in svg (tens of Mb) |
Print at Sep 20, 2026, 2:29:49 AM |
| Posted by Daniels118 at Feb 12, 2022, 1:31:11 PM |
Re: Floor have huge size in svg (tens of Mb) What follow is non a solution, just some considerations useful for further analysis. It seems SH3D encodes the pattern for all the walls in a single PNG image when exporting to the SVG format (the PNG is embedded into the SVG). This means even if you have just 2 small walls, the farther they are, the larger the image will be. Now this shouldn't be a great problem, because PNG supports compression and the blank space between walls is prone to give high compression ratios. The problem is the PNG image is produced without compression ![]() In fact, I have achieved small file size even without resampling the PNG, just running an optimizer. I will take a look to the code responsible for the exporting, but maybe Puybaret already know where and how to fix the issue. |
Current timezone is GMT Sep 20, 2026, 2:29:49 AM |
