Print at Oct 5, 2026, 8:22:02 PM
Posted by Daniels118 at Jan 21, 2022, 5:15:56 PM
shock   Re: Wirings plugin
Warning! I discovered a bug using wirings with levels. When you draw wirings they are correctly assigned to the active level. However when you save the file the level of each wiring is not saved. So, when you reopen the file, the wirings are all added to the active level, regardless of the level they were originally.
This bug will be fixed in the next release, a popup message will inform you if your file contains such wirings.
Apologize me for the inconvenience. praying
