Print at Sep 10, 2026, 1:56:25 AM
Posted by Puybaret at Jan 17, 2022, 10:33:05 PM
Re: Defective autosave
You might have encountered the same issue as in the bug #1075.
First, be sure that the auto save is probably the best solution in a JavaScript environment where a crash with a page reload may occur at any moment when resources are missing. I see from the server logs that the exports you obtain from your 3 projects contain the last changes received by the server.
But let's try to understand why the server didn't receive the last changes you made. I hope you kept the windows of your 3 projects opened (or at least one), so you can report what the content of the JavaScript console.
Display it by choosing the menu item More tools > Developer tools (Ctrl+Shift+I) and select the Console tab. The Console should contain some lines stating
Failed to load resource: the server responded with a status of 404 (Not Found)
and if it contains some other texts, please copy-paste it here because it could explain what's going on.
