Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: A Service Hatch leaves a white stripe on the floor. Can this be avoided? » » » » Post: Re: A Service Hatch leaves a white stripe on the floor. Can this be avoided? |
Print at Sep 10, 2026, 3:26:09 AM |
| Posted by hansmex at Jan 15, 2022, 10:16:05 PM |
Re: A Service Hatch leaves a white stripe on the floor. Can this be avoided? If you insert an inverted u-shaped object into a wall, the wall will fill up. If you add a closing part at the bottom, that part will leave a gap in the floors you insert afterward. The trick is to make an insert with a bottom closing part that is as thin as possible, making it almost invisible. H ---------------------------------------- Hans Ryzen 7-9700X, 32 GB RAM, 500 GB SSD, 2x 2 TB SSD, Geforce GTX 1060 3 GB |
Current timezone is GMT Sep 10, 2026, 3:26:09 AM |
