Print at Sep 14, 2026, 1:05:51 AM
Posted by Daniels118 at Dec 6, 2021, 10:58:25 PM
Re: Pan tool in 3D and 2D view?
I've published the new version, here are the improvements:
- almost fixed the polyline selection bug (now only happens while creating the polyline);
- selected objects are never hidden;
- the hiding behaviour is much better.
Hiding criteria
Hiding is now performed based only on the X-Y plan. Hiding using a polyline works as before, the only difference is that now the wall detection is made on the whole length, giving much consistent results even with long walls. Automatic hiding works as follow:
- if the camera rotation centre is within a room, a hiding threshold is built by shrinking the room shape. This produces very good results, which are affected mostly only by the camera orientation.
- If the rotation centre isn't within a room, the hiding threshold is a straight line parallel to the screen and passing through the rotation centre. This gives good results when rooms aren't defined yet.
