Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Viewing levels in 3d view from same position » » » » Post: Re: Viewing levels in 3d view from same position |
Print at Sep 10, 2026, 2:35:17 AM |
| Posted by Puybaret at Dec 1, 2021, 3:57:52 PM |
Re: Viewing levels in 3d view from same position You can retrieve the coordinates of the Aerial view camera in the Home.xml file of a SH3D file. As a SH3D file is actually a ZIP file, open it with any zip tool, the view the Home.xml file it contains and look for the line starting by <camera attribute='topCamera' where you'll get the values of x, y, z (=elevation), yaw (=body angle), pitch (=head angle) and fieldOfView attributes. Then, copy these values in the Virtual visit modification box (angles should be converted from radians to degrees). [Edit: it looks like you found the solution by yourself ]---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Sep 10, 2026, 2:35:17 AM |
