Print at Sep 21, 2026, 6:20:58 AM
Posted by otadmin at Sep 11, 2021, 9:29:10 AM
Re: Guide: Pipes
Thanks for the guide. I want to draw water/heating pipes and electrical wires normally hidden inside walls.
It is quite possible to draw the objects inside walls and make them visible/invisible by "Modify 3D view - Wall transparency". They can also be put into floors of rooms but only if the elevation is set from the room below.
I group the objects as you suggested and can then hide/show example only the heating pipes.
