Print at Sep 6, 2026, 7:03:24 AM
Posted by Puybaret at Aug 23, 2021, 8:18:54 PM
Re: Trying to understand how to run a locally modified/built SH3D
The SweetHome3D-version.jar file generated by the default Ant target is a JAR Executable file that can be run with a command like:
java -jar /path/to/SweetHome3D-version.jar
If you want to run it with the same options as SweetHome3D-Java3D-1_5_2, you should add the option -Dcom.eteks.sweethome3d.j3d.version=1.5.2 after java command, i.e.
java -Dcom.eteks.sweethome3d.j3d.version=1.5.2 -jar /path/to/SweetHome3D-version.jar
