Sweet Home 3D Forum » List all forums » » Forum: Sweet Home 3D bar » » » Thread: how to make sloping and curved walls or roof? » » » » Post: Re: how to make sloping and curved walls or roof? |
Print at Sep 20, 2026, 2:16:15 AM |
| Posted by hansmex at Aug 15, 2021, 1:08:03 PM |
Re: how to make sloping and curved walls or roof? See attached file 1 - in top view, draw the outline of walls, floor and ceiling 2 - add a room with floor, no ceiling 3 - make wall height half the width of your caravan 4 - insert doors and windows, rotated 90 degrees 5 - apply textures etc 6 - export as OBJ file, selection only 7 - import and rotate 90 degrees 8 - copy once, mirror and rotate, then join the halves Disadvantage: Walls can be seen from the inside, not from the outside This could (probably) be solved by exporting just the floors (second time) and applying these to the outside. Note: Standard doors and windows can not be inserted in floors. Use your own doors and windows, import them as stairs, and see if that works better. H ---------------------------------------- Hans Ryzen 7-9700X, 32 GB RAM, 500 GB SSD, 2x 2 TB SSD, Geforce GTX 1060 3 GB |
Current timezone is GMT Sep 20, 2026, 2:16:15 AM |
