Sweet Home 3D Forum » List all forums » » Forum: Developers » » » Thread: Replace light sources plug-in » » » » Post: Re: Replace light sources plug-in |
Print at Sep 15, 2026, 7:15:02 AM |
| Posted by enkonyito at Aug 10, 2021, 5:24:06 AM |
Re: Replace light sources plug-in Hans, The plug-in is compatible with SweetHome3D-6.5 and higher because it uses the new setLightSources method. This version 1.2 no longer takes into account the selection of light sources from the furniture catalog (CatalogLight class). It only takes into account the selection of light sources from the plan or from the furniture list (HomeLight class). Detailed guide: 1- Add to the plan a lamp with integrated light source (SweetHome3D library or personal light library) 2- Add in a corner of the plan or in a specific level a light source model (SweetHome3D light sources or light spheres that I created) 3- Select the lamp whose sources you want to modify and the light source model whose color you want to use 4- In the Tools menu, click on the plug-in action (this can be canceled in several times) 5- A message is displayed: "No light source model !" or "No visible light selected !" or "Light sources replaced." 6- Uncheck the Visible box of the light source model modification panel or make the specific level non-viewable 7- Make a photo rendering in quality 3 or 4 to see the result The default photo panel does not take into account (for the moment?) the colors of negative value (#FF8000). Enko ---------------------------------------- EnkoNyito |
Current timezone is GMT Sep 15, 2026, 7:15:02 AM |
