Print at Sep 14, 2026, 2:17:28 AM
Posted by AlexQ at Aug 9, 2021, 5:37:29 AM
Re: Texture turned out different from Texture applied to cabinet.
Hi Hansmex,
To apply texture to cabinet, I have only used the built-in feature of 'texture' and 'color'. And it was not successful, as I had not reduced the size of the wood5 texture to 75 cm x 75cm to match the physical width of the cabinet of 800 mm. This you pointed out in your earlier reply.
But I noted you have used "Furniture Materials"-'Model materials' instead to do the texture/color changed for the cabinet.
https://www.mediafire.com/view/ylw2c472di3nyk0/modify_material.jpg/file
In the 'Model materials' there are 4 colors viz. flltgrey, grey,ltgrey and white. And Shininess set to 'matt'
My guess is you took the 'cabinet model' and do something to it which I'm not sure how it is done. I search but couldn't find relevant information required for me to follow.
Can you kindly explain how to do this as I have a really steep learning curve to climb?
or if there is a detailed step by step tutorial with images on how to do this, can lead me there, please ?
May I know if "SunFlow rendering engine" is downloadable from SH3D site? I don't think I have this feature in my model. Is it absolutely necessary to get to the "right color & texture"?
I try to keep things simple for now.
Thank you. Have a nice day!
Alex Quek
