Sweet Home 3D Forum » List all forums » » Forum: Wishlist » » » Thread: More precision in the measurement fields » » » » Post: Re: More precision in the measurement fields |
Print at Aug 21, 2026, 4:57:45 PM |
| Posted by ssandison at May 24, 2021, 12:00:05 PM |
Re: More precision in the measurement fields Maybe there could be an option set somewhere to enable more precision. That way by default it behaves as it does now but if you need more than a millimetre you can enable that if needed. Maybe this hasn't ever come up before. My issue is that we have an image with white clouds on it and if you make the background transparent there is a shadow created that makes the clouds look darker than they are and we would want them to be. To resolve this you need the background colour of the image to be the same as the wall but then by default you will get a line around the image as it's not totally on the wall. I always move the image as close to the wall as possible because it never snaps totally onto the wall by default so you need to do this with the coordinates but even with doing that it doesn't get close enough with a solid background colour so causes a faint line in rendering. |
Current timezone is GMT Aug 21, 2026, 4:57:45 PM |
