Print at Aug 21, 2026, 4:58:01 PM
Posted by ssandison at May 21, 2021, 5:31:46 PM
More precision in the measurement fields
Is it possible to increase the precision in the measurements fields so that I can more accurate position items?
I'm trying to place an image on a wall using a box with an image as a texture and it needs a solid background colour for it to look right.
Anyway a faint line appears unless I position it with more precision than is available in the field. It accepts the value 112.56 but if you edit the item again it will show the value 112.6. Are you able to change the field type so it accepts 112.56 and maybe even greater precision numbers?
Example image here:
https://pasteboard.co/K2VGeua.png
