Print at Sep 6, 2026, 9:31:43 AM
Posted by Puybaret at May 7, 2021, 3:31:10 PM
Re: Problems Importing
The colors and textures of an OBJ file are defined in a MTL file and images which should be in the same folder or the same ZIP file when you import the OBJ file.
What do you mean by "off axis"? If they are not correctly oriented, the second step of the furniture import wizard should help you to fix that.
