Print at Aug 24, 2026, 10:40:04 PM
Posted by Clamarc at Apr 25, 2021, 3:13:25 AM
Re: Columns in the plan and correct position of creation of the house
Hi Puybaret,
I verified that the problem is related to the following Use Case:
- When we choose the "Select all" or "Select all at all levels" options, all furniture that has "Invisible status" IS NOT MOVED. That way, they stay in the original place, while the other objects and the house are moved to where we want. For this reason, when we close and reopen the program, the columns where these invisible furniture are located are not removed.
It would be interesting that when we use the options "Select all" or "Select all at all levels", the furniture with "invisible status", is also selected so that they are moved along with the other objects in the plane.
thanks
Clamarc
