Sweet Home 3D Forum » List all forums » » Forum: Developers » » » Thread: Good practice for derived version of Sweet Home 3D » » » » Post: Re: Good practice for derived version of Sweet Home 3D |
Print at Aug 21, 2026, 7:15:39 AM |
| Posted by enkonyito at Apr 7, 2021, 6:44:23 PM |
Re: Good practice for derived version of Sweet Home 3D If the purpose of this derived version is only to handle individual light on ceilings as explained here, I think you could manage this feature with a plug-in that would modify the property of your choice on room instances. Properties are saved in SH3D files and you may even listen to their change from version 6.4. This derived version also offers the grouping of actions of the same plug-in in a menu.A plug-in would also prevent from generating updates for each new version of Sweet Home3D. This time around I added a new CEILING_LIGHT_POWER property and a ceilingLightPower spinner in the edit room panel. Is it also possible to manage them from a plug-in as you suggested? If you want to build a portable version, you'll need a macOS computer for some parts as you correctly read (I gave some explanations about building the portable version in a comment of this blog article), but you could avoid it by reusing the existing portable version since you probably just want to change only SweetHome3D.jar file. As I have been using the portable version for 1 year mainly with a configuration file, I had not noticed this old article.Not having macOS, how to reuse portable version 6.5 with the derived jar file? Finally, about where to host derived versions, it's up to you to decide. Just keep in mind that "Sweet Home 3D" is a registered trademark owned by eTeks, and it can't be reused anyhow. If that were to be done, I thought to change the name by putting a reference to "Sweet Home 3D".---------------------------------------- EnkoNyito |
Current timezone is GMT Aug 21, 2026, 7:15:39 AM |
