Print at Sep 10, 2026, 1:32:55 AM
Posted by snmavronis at Mar 9, 2021, 1:34:01 AM
Levels Elevation Change
In the Modify Level dialog box if I change the 3 level's elevations so that the basement is 0' elevation and adjusted the other 2 levels relative to that, do each item's elevations within each level adjust accordingly so everything looks the same as before? I want to raise the entire house so I can make the proper landscape outside that slopes away from the house, because ground level is several feet below the main level elevation.
