Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: fill space in between internal/external walls » » » » Post: fill space in between internal/external walls |
Print at Sep 24, 2026, 12:42:12 AM |
| Posted by andreab82 at Feb 22, 2021, 9:22:01 PM |
fill space in between internal/external walls Hi, I drew the external walls from the floor plan. Then I created the rooms with internal walls. Now I find myself with massive gaps which are not nice to look at. Here is what I'm talking about: https://ibb.co/PMsczB2. It's an old house, so some walls are very thick (60/70cm). Also, as you can see form the pic the thickness is not consistent. Continuously changing the wall thickness wasn't very convenient. In summary, is there a way to fill the space in between? The only alternative I can think of (to fix this after the fact) is to set the wall thickness to something average (eg 25cm) and draw layers and layers of walls filling the gaps. It should work, I just thought it's not a very elegant solution. Thanks in advance for any suggestions. Regards, Andrea |
Current timezone is GMT Sep 24, 2026, 12:42:12 AM |
