Print at Sep 19, 2026, 7:57:25 PM
Posted by alied at Feb 7, 2010, 7:14:39 PM
Re: Is it possible to give Texture to Furniture?
Well, that was a rough outline. I've changed textures on-the fly, but I've allways tried to have a dummy texture before (to know where to do the change) with a named material.
private void deepUpdateMaterial(Node node) {
if (node instanceof Group) {
Group bg = (Group) node;
for (int i = 0; i < bg.numChildren(); i++) {
Node shape = bg.getChild(i);
deepUpdateMaterial(shape);
} else if (node instanceof Shape3D) {
Shape3D shape = (Shape3D) node;
Appearance material = shape.getAppearance();
if (material != null) {
shape.setAppearanceOverrideEnable(true);
String texture = null;
Here, set the texture to whatever is to set
if (texture != null) {
BufferedImage textureImage = null;
try {
textureImage = ImageIO.read(new URL(texture));
} catch (IOException ex) {
// Ignore images at other format
if (textureImage != null) {
TextureLoader textureLoader = new TextureLoader(textureImage, TextureLoader.GENERATE_MIPMAP | TextureLoader.BY_REFERENCE);
material.setCapability(Appearance.ALLOW_TEXTURE_ATTRIBUTES_WRITE);
material.setCapability(Appearance.ALLOW_TEXTURE_WRITE);
material.setTexture(textureLoader.getTexture());
That is how I do it, and it works. Emmanuel, some of this code would seem familiar to you :-). Anyway, in this case there is already a defined material. If there weren't any, you should have to list all shapes and assign a texture for each, and create materials as needed.
Why not to post this to the developpers forum, in case someone wants to try?
