Print at Feb 4, 2026, 7:23:38 PM
Posted by GhyslainB at Jan 31, 2021, 8:50:48 AM
Re: YafaRay rendering plug-in
I've been using Yafaray since last summer, and overall I've had a good experience. However, I have three lingering issues, and I wondered if I'm just clueless on using the software properly (quite possible), or if they are the result of bugs.
Note: I typically use Yafaray at Level 4, with Photon, Lanczos and Shinydiffusemat, but I have seen the same issues with every setting I've tried.
1) First, I use some mantle clock furniture objects, and somehow whenever I render them with Yafaray, the clock face is missing, like this:
For reference, with SunFlow, they render properly, like this:
2) Secondly, the lamps (from SH3D default furniture set) are lighting incorrectly; the light "shines through," even when the lighting is set at a low percentage intensity. Like in the following example (lamp set at 7%):
3) Finaly, when using the Multiple photo rendering (v.2.1) plug-in, there seems to be some kind of memory management issue. The memory used by SH3D keeps getting larger with each render, usually leading to a crash when it goes above 200 GB or so, which is about 4-5 renders on a .sh3d file of about 1.75 GB. I can live with restarting the app every 4 renders, it's not a big deal, but I thought maybe it could be useful to report the problem here.
Thanks in advance for the help!
