Sweet Home 3D Forum » List all forums » » Forum: 3D models and textures » » » Thread: About wall » » » » Post: Re: About wall |
Print at Sep 20, 2026, 9:26:04 PM |
| Posted by snmavronis at Jan 29, 2021, 2:11:03 AM |
Re: About wall I uploaded a 1/8" thin (3-sided) doorway frame that won't leave a white edge on the floor. I created it for a large wall opening between my kitchen and dining room using the Furniture Library Editor and SVG code. It can be resized. I also did the same thing to create the slightly arched opening between my living room and dining room. I choose 1/8" thin frame edge thickness to get a "frame-less" as possible for simple wall openings. [EDIT: I deleted my prior post and combined in with the following.] Use this instead. It's a SH3F furniture library with the correct "door" versions that cut a hole in a wall. I think the other files I posted were the original versions of the opening shapes as an OBJ export. I'll delete those from my Google Drive to avoid confusion. Download the whole file (not the individual contents) and import into SH3D. I'm new at creating custom models so sorry for the screw up. I need a better workflow process. ;) https://drive.google.com/file/d/1Mpoci-7JktEU...lvv3yXZl/view?usp=sharing ---------------------------------------- Steve N Mavronis - Retired PC Tech |
Current timezone is GMT Sep 20, 2026, 9:26:04 PM |
