Sweet Home 3D Forum » List all forums » » Forum: 3D models and textures » » » Thread: Door Frames » » » » Post: Re: Door Frames |
Print at Sep 9, 2026, 11:20:29 PM |
| Posted by Puybaret at Jan 13, 2021, 1:05:43 PM |
Re: Door Frames If you want the shape seen in your image, draw its contour with thin walls in a new document, rounding the wall matching the top part, and set the color of the both sides of the bottom part with a different color. Then select the 4 walls, choose File > Export to OBJ format menu item and the option Export selection when prompted. Once the OBJ file is exported, import it with the Furniture > Import furniture menu item. During the second step of the import wizard, rotate the shape to get the round part at top, and during the third step, select the Door or window option. Place the imported shape on a wall and finally, change the material of the bottom part to make it transparent. You'll get the result in the attached file. You could also read this guide which explains how to define the cutout of a door. ---------------------------------------- ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Sep 9, 2026, 11:20:29 PM |
