Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: SH3D refuses to save my file » » » » Post: Re: SH3D refuses to save my file |
Print at Sep 25, 2026, 11:22:45 PM |
| Posted by Puybaret at Feb 2, 2010, 2:18:19 PM |
Re: SH3D refuses to save my file In case you're under Mac OS X and you're not afraid to use Terminal, here's also an other tip to recover a file as it was before you opened it. A user tested it successfully a few days ago. He was forced to quit Sweet Home 3D, and when he relaunched it, his SH3D file was corrupted: - In Terminal application, launch the following command: sudo ls /var/folders/*/*/-Tmp-/open*.sweethome3dThis command requires the administrator password and will list the opened SH3D files before Sweet Home 3D crashes (normally these temporary files are deleted when Sweet Home 3D normally quits). - If Terminal lists some files, copy them on your Desktop with this command: sudo cp /var/folders/*/*/-Tmp-/open*.sweethome3d ~/Desktop- Finally, replace the .sweethome3d extension by .sh3d extension to be able to open the recovered files with Sweet Home 3D. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Sep 25, 2026, 11:22:45 PM |
