Print at Sep 9, 2026, 11:20:43 PM
Posted by Puybaret at Jan 10, 2021, 10:37:34 PM
Re: Exporting Models or simple Kitchen furniture sample
Nice start! wink
The easiest way is probably to add the model you want to change to the plan, select the 3D View > Export to OBJ format menu item, choose Export selection when prompted (you may also find the OBJ files at https://sourceforge.net/p/sweethome3d/code/HE.../3DModels/blendswap-cc-0/ ).
Then import in Blender the exported OBJ file with File > Import > Wavefront (.obj) menu item, modify your model and reexport it with File > Export > Wavefront (.obj) menu item.
Finally, reimport the generated OBJ file in Sweet Home 3D with Furniture > Import furniture menu item.
If the model is partly visible in Blender, reduce its scale because Blender works in meters and Sweet Home 3D in centimeters.
