Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Can someone please explain plan view "other level' wall visibility? » » » » Post: Re: Can someone please explain plan view "other level' wall visibility? |
Print at Aug 19, 2026, 10:30:40 AM |
| Posted by Puybaret at Dec 26, 2020, 1:33:35 PM |
Re: Can someone please explain plan view "other level' wall visibility? As you observed, only wall guides of the previous level can be seen in the edited level, or at the lowest level guides of its upper level. The idea is that you draw a level, then need guides in an upper level, or in a basement. having some attributes in the level settings like "visible" [...] would be simpler It will make the program too complicated, because you would have to detail also in which other levels you want a level to be visible, otherwise you would get many guides for houses with multiple levels.You could simply copy paste walls from a level to another one and remove the ones you don't want to keep, or program you own version, as you decided to do. Therefore the order of adding levels impacts behavior. No, you missed the fact that levels are always ordered from the lowest level to the highest, then at the same elevation, in the elevationIndex order set in the level modification dialog with the arrows at the right of Levels summary list.the current code violates UI first principles What principles do you have in mind?---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Aug 19, 2026, 10:30:40 AM |
