Sweet Home 3D Forum » List all forums » » Forum: New versions » » » Thread: YafaRay rendering plug-in » » » » Post: Re: YafaRay rendering plug-in |
Print at Sep 14, 2026, 3:05:45 AM |
| Posted by enkonyito at Nov 13, 2020, 4:19:16 AM |
Re: YafaRay rendering plug-in @bam0o Hi, guys! Can you tell me, why rendering with natural light is too dark? I've drawn a room with 4 walls, floor and ceil (17 sq.m). Placed simple double window. And a table inside (just for example). Placed virtual visitor and made yafaray render. (window to the NE side and 8AM - morning - very thin stripe of sunlight on the wall) Until I turn on ceil lighting images are very dark - almost black room with window and sunlight stripe! Sky lighting doesn't help. Only ceil lighting... What I do wrong? Or is it normal? I'm trying to compare with real life and my room with the same conditions is much lighter at morning. (yes, i know about aperture and shutter time in photography, but...) Can I setup renderer to make pics closer to real life with natural lighting? I've tried AO and path tracing modes - same results... Without additional light sources, an interior rendering is always dark. If you want to have a natural rendering, you can use path tracing global illumination by increasing the number of light bounces if necessary. Turning on the sky lighting (without texture) can bring a little more brightness. You can also add light panels as suggested ceciliabr by paying attention to the light power so that it stays close to reality. Enko ---------------------------------------- EnkoNyito |
Current timezone is GMT Sep 14, 2026, 3:05:45 AM |
