Print at Aug 26, 2026, 3:05:22 AM
Posted by DerekvG at Oct 29, 2020, 1:37:44 PM
Re: SH3D on Ubuntu 20.04 LTS
I don't want to start it from terminal because the terminal window stays open. Further more it is not listed in the Application selector
I prefer starting it from Nautilus because I know it works, whereas whan I start if from terminal things go wrong and work gets lost. ( I have been working like that since feb/march of this year whan I reinstalled and had the same problem and instability over and over again.
Moreover I can save the launcher instance to luncher favourites and i can restart it from the launcher bar
The Bundle in the distro is out of date 5.x( if i'm not mistaken) it's not even worth to install
BTW =============
on my last start in Terminal following errors showed up
... ~/SweetHome3D-6.4.2$ ./SweetHome3D
Gtk-Message: 11:28:55.194: Failed to load module "canberra-gtk-module"
Exception in thread "pool-8-thread-1" java.lang.NullPointerException
at com.eteks.sweethome3d.swing.ImportedTextureWizardStepsPanel$19.run(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624)
at java.lang.Thread.run(Thread.java:748)
