Print at Sep 14, 2026, 1:49:31 PM
Posted by aleksei5698 at Oct 8, 2020, 7:23:13 PM
Re: possibility to break the line of the name's field of furniture
Hello Emmanuel, thank you for your kind reply. My problem is: I have plans of several building levels. In this plans I have designed Infrared heating panels on the ceiling. I want to check which are the technical attributes of those panels in order to show them to the electrician. But the "names" of these panels are to long:
HVH600 119,2x59,2 600W
they are overpassing the sizes of the panels and are disturbing the plan.
Therefore I should have the names in this format:
HVH600
119,2x59,2
600W
I could do this with an extra text field. But this field should be connected to the heating panel on order to be able to move them together. Unfortunately I am not able the create a group with the text and the object.
Is there any solution?
Hello Friedrich
Have you found solutions to this problem?
Indeed, it is very inconvenient that there is no way to display the name on
multiple lines. And the text with furniture, as you noticed, is not grouped.
