Sweet Home 3D Forum » List all forums » » Forum: Sweet Home 3D bar » » » Thread: 3D model request: Pie shaped primitives » » » » Post: Re: 3D model request: Pie shaped primitives |
Print at Sep 20, 2026, 1:41:06 AM |
| Posted by coldcomfort at Aug 31, 2020, 1:29:47 PM |
Re: 3D model request: Pie shaped primitives Another way to do it, if you don't want to make the shape in sketchup, is by using the triangular box. Make the steps over sized, going through the walls to fill the space. And where there's an empty space left just fill that with another smaller triangle, oriented accordingly. It is the most straightforward way, short of making the exact shape that you need. P.S.There's a little glitch though, some holes will appear in the ground surface projected from the smaller triangular boxes inside the wall. Easy to patch with, you guessed it -another triangular box-. It's triangular boxes all the way down. |
Current timezone is GMT Sep 20, 2026, 1:41:06 AM |
