Print at Aug 25, 2026, 11:49:35 AM
Posted by messefilme at Aug 27, 2020, 1:48:48 PM
Re: Scaling issue for the background image, wrong aspect and size
I just noticed that this problem occurs when you connect 2 or more walls. When I create a single wall it fits to the size of the background image. But if I create a second wall and combine them the value inside the distance field shrinks. For example: Wall without connection = 888 cm. Wall with connection to another wall, 90° shifted will reduce the value to 875,9 cm.
I learned that I need to work with uncombined walls to have a correct value for the length of the wall.
