Print at Aug 25, 2026, 11:49:49 AM
Posted by messefilme at Aug 24, 2020, 5:59:23 PM
Re: Scaling issue for the background image, wrong aspect and size
Thanks for the answer: I scaled it again to 888 / 863 because the CAD drawing contains the walls. It did not help. Then I changed it to 863 / 845 but nothing is changing. The result is still the same. The background image is smaller than the manually created walls but the settings of the walls shows me correct size of each wall.
Should I trust the imported background or the wall sizes? I can start from scratch drawing new walls but I'm not sure if the plan will be correct afterwards.
