Sweet Home 3D Forum » List all forums » » Forum: New versions » » » Thread: Sweet Home 3D 6.4.2 » » » » Post: Re: Sweet Home 3D 6.4.2 |
Print at Sep 23, 2026, 8:49:01 PM |
| Posted by Mike53 at Aug 23, 2020, 4:05:50 PM |
Re: Sweet Home 3D 6.4.2 Sorry Emmanuel, i had not thought of you needing it, i deleted it to start over .If it helps..... the only way i found that corrected some of the issue was to re-draw the walls, this however still meant that 1 corner still had the issue. I concluded that walls joined in 6.4.0 were not happy opened in 6.4.2 I did recall that whilst the walls were not split, as you mentioned before, 1 of them had been cut/pasted, hence the need to join them. |
Current timezone is GMT Sep 23, 2026, 8:49:01 PM |
