Print at Aug 25, 2026, 9:54:32 AM
Posted by jbhk at Aug 17, 2020, 9:45:59 PM
After you've imported blue print and traced ...
Two parts:
Once you have imported your blue print and traced the walls, can you get rid of the background image?
Can you coppy your walls only into a new file? I'm trying to use the original plans as a starting point to place and plan a guest house on the same property, so I need to enlarge the file/project to accommodate the land/lot size, not just the residence size. Is there a way to do this?
Thank you
