Print at Oct 9, 2026, 6:14:09 AM
Posted by Mike53 at Jul 13, 2020, 12:46:58 AM
Wall mods
Started this thought (wish) in another topic but felt it needed its own. As Emmanuel already answered i will start with a reply. Whether i use plan > modify walls or right click > modify walls, selecting multiple walls does not allow for changing the arc. I use walls and rooms for creating many objects, the down side of this is that each arc is multiple straight lines. what i currently do is create a room, for example a dodecagon, add walls all around it, with the wall creation tool and double clicking on the room, this gives me 12 individual walls, i then have to select each wall individually and change its arc to give a a truer circle, then i can create the room inside it. Changing the arc on multiple walls would simplify the process. I used a similar process recently to create the pillars on a cabinet, where i used a negative arc on every 3rd wall.
