Sweet Home 3D Forum » List all forums » » Forum: Wishlist » » » Thread: NegativeAllow the elevation of the object to be negative! » » » » Post: Re: NegativeAllow the elevation of the object to be negative! |
Print at Sep 20, 2026, 5:35:16 PM |
| Posted by harbinger at Jul 7, 2020, 10:15:41 PM |
Re: NegativeAllow the elevation of the object to be negative! Bumping this to keep this feature request alive. With many of my architectural plans, ceilings are lower in different rooms but much lower than the height of the level and so I put in soffits to account for the ceiling space in the shorter rooms. The problem is, since we can't put in a negative elevation, i have to elevate it on the lower level. When I then preview that level, the ceiling soffit shows up on the lower floor and I can't see the wall layout of that floor. If I could apply a negative elevation to a soffit which is being used to block off a ceiling, I could assign it to the floor above so that the soffit doesn't block the view. |
Current timezone is GMT Sep 20, 2026, 5:35:16 PM |
