Sweet Home 3D Forum » List all forums » » Forum: Installation » » » Thread: Portable 6.3 + Editors? » » » » Post: Re: Portable 6.3 + Editors? |
Print at Aug 1, 2026, 4:37:34 PM |
| Posted by Puybaret at Jul 2, 2020, 10:08:25 AM |
Re: Portable 6.3 + Editors? Yes, you may reuse the Java environment included in the Portable version to run editors if needed: find in the jre folder the java or javaw executable of Java, and run it in a command followed by -jar and the path to the JAR executable file of the editor. Using a cmd or Terminal window, this should take a few seconds if you follow these instructions: 1. Drag and drop the java or javaw executable in the cmd or Terminal window to copy its full path in it 2. Type a space, -jar and another space 3. Drag and drop the icon of the JAR executable file in the cmd or Terminal window to copy its full path in it 4. Type <Enter> Under macOS, something like: /pathTo/SweetHome3D-6.3-portable/jre/macosx/x64/jre8/Contents/Home/jre/bin/java -jar /pathTo/FurnitureLibraryEditor-1.25.jarIf you want to reuse the same command often, consider saving it in a command file (.bat under Windows). ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Aug 1, 2026, 4:37:34 PM |
