Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: cannot generate best quality photo and 3d view window is lagging » » » » Post: Re: cannot generate best quality photo and 3d view window is lagging |
Print at Sep 29, 2026, 11:46:37 AM |
| Posted by Puybaret at Jun 24, 2020, 12:25:34 PM |
Re: cannot generate best quality photo and 3d view window is lagging You probably use a complex 3D model that slows down Sweet Home 3D. As the most complex models use generally a larger file, I would suggest to display the Model size column in the furniture list, then sort the list by model size order by clicking on Model size column and make the largest model invisible to check if it works better. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Sep 29, 2026, 11:46:37 AM |
