Print at Oct 15, 2026, 6:59:58 AM
Posted by Puybaret at Jun 14, 2020, 8:30:51 PM
Re: YafaRay rendering plug-in
This installer comes with its own copy of Java 8, the reason why it’s much larger than the older ones. So there’s no reason why it would try to use Java 6.
I would suspect that you have more than one copy of Sweet Home 3D application on your computer and another version is associated with .sh3d documents.
This could happen if you open Sweet Home 3D by double-clicking on a SH3D file.
First try to launch Sweet Home 3D by clicking on its icon in the DMG you downloaded or a copy of it on you disk. Then if it works, try to remove the other Sweet Home 3D applications or change file associations in macOS if you know how to perform this change.
