Print at Aug 21, 2026, 6:29:19 AM
Posted by Puybaret at Jan 4, 2010, 8:11:19 AM
Re: Excellent, excellent program...
You can change the default thickness and height of walls in the Preferences pane.
Note also that when you create walls with the keyboard (in Wall creation mode, type enter key to type values in the wall tooltip), the thickness you enter will be kept from one wall to the next one.
One last tip: the easiest way to design just one room is probably to draw it first with the Room creation tool, then choose Wall creation mode and double-click in the room to automatically create the walls around it.
