Print at Aug 21, 2026, 7:51:53 PM
Posted by Puybaret at Apr 25, 2020, 7:55:39 PM
Re: Using SH3D Portable's Java Files to Run the TLE & FLE
I'm not sure you can change the launch parameters if java is not installed.
If you want to reuse the command you should rather store it in a .BAT file.
And when you say "I may use javaw.exe", what does that mean?
Simply replace java.exe by javaw.exe in the command I wrote.
