Sweet Home 3D Forum » List all forums » » Forum: Installation » » » Thread: Texture Library Problems » » » » Post: Re: Texture Library Problems |
Print at Aug 19, 2026, 10:49:11 AM |
| Posted by T3NZ3N at Apr 23, 2020, 5:43:56 PM |
Re: Texture Library Problems Here are the things I tried: Stripping all data, Resizing images to all be the same square size, Converting to different image Formats like BMP & PNG, renaming without spaces or dashes or special symbols, being sure all fields were filled out in the TLE, and exporting several smaller groups of textures instead of one large one. I wonder, is there a limit to the number of images or size of the sh3t file? Even my smaller ones didn't work, however. As for the TLE Interface, I would like to suggest the following: the Undo button. I know i read that they didn't think it was necessary, but I think it's very important, and here is why: If we want to break one larger sh3t file into several smaller ones, we can delete the ones we don't want then save as, and it would be nice to hit undo to repopulate the list to replace everything that was deleted on export, and delete different ones. ALSO, if we accidentally put the category in the name box because we were distracted, we could just undo instead of starting all over. It would also be very great if you could Prevent the Name Field from being active at all while editing multiple items, since you shouldn't use the same name for two different textures anyway, and to help prevent accidental category name being entered in name field. Also, When "Creating New", the files from the original somehow populate with the new one opened, often just appended to the end as a bunch of duplicates. I think this happens especially if they have the same name or are the same sh3t file. Therefore, if you could add a "Close Database" option that asks to save changes, it would close it out completely before opening another one. The 'New' function doesn't exit the database completely, and you are only asked to save invisible databases when exiting the entire program, not when creating New, meaning the open one is still lingering around somewhere in there. or perhaps make some tabs that show the open databases. It would also be great if it could Remember the last directory when opening. And useful also if it could automatically Check for Updates Those are my suggestions to make the TLE much better. |
Current timezone is GMT Aug 19, 2026, 10:49:11 AM |
