Sweet Home 3D Forum » List all forums » » Forum: Installation » » » Thread: Texture Library Problems » » » » Post: Texture Library Problems |
Print at Aug 19, 2026, 10:49:01 AM |
| Posted by T3NZ3N at Apr 23, 2020, 5:24:31 PM |
Texture Library Problems I can install all 8 of the Contributions and eTeksScopia Texture sh3t libraries, and they import great into sh3d, but I haven't been able to import any of my own texture libraries. Looking at the Contributions & eTeksScopia libraries, I noticed they all had a folder structure like "Folder/folder", such as "Contributions/contributions/*.jpgs", whereas the export from TLE has simply "Folder/*.jpgs". The subfolder has no capital letters, and I'm assuming it can't have spaces or special characters either I also noticed that the "PluginTexturesCatalog.properties" file, when I exported from the TLE, was in the same folder as the image files, but in the Contributions & eTeksScopia libraries they were in the top folder. I also noticed that in the "PluginTexturesCatalog.properties", each image file is listed with an ID=, which I read can "be added with a small tweak to the program", but I don;t think any users are going to be making tweaks to the programming. Then, the Name from TLE is simply "name#1=Birch 2", but the name from the official ones are in the format of "name=Birch bark", with the category listed after the name, and no numbering present after the name, even if the name field said "Birch2" I also noticed the "image#" path goes to the subfolder and the path looks like "/subfolder/birch_bark2.jpg", noting there is no spaces, and all spaces have Underscores in their place. On my TLE export, however, the image# has FORCED spaces. I renamed all of my images with AdvancedRenamer to remove all spaces in the name. I then, just to be extra sure, reconverted all of my images and ripped out any EXIF, or other data & profiles, making a completely new file, rebuilding the thumbnail, with no extra data inside. HOWEVER, when I imported them into the TLE, all the fiel names had spaces between the name and the number. For example, an image named "Birchbark1234" appeared as "Birchbark 1234" in the TLE. I suspect this is the problem. So in my "PluginTexturesCatalog.properties", my image# name has spaces, whereas the official libraries are carefully named to not have any spaces. And when I try to import the sh3t file into sh3d, nothing happens. I don't understand why or HOW the TLE is adding spaces to my file names which clearly don;t contain the data for spaces in the file names. |
Current timezone is GMT Aug 19, 2026, 10:49:01 AM |
