Print at Aug 15, 2026, 4:35:11 PM
Posted by CarlosManuel64 at Apr 9, 2020, 10:32:37 PM
smile   Re: Transparency on objects strange
Merci bien.
I was able to get what I want as you can see on the pictures.
But have found something curious (for me).
Because the texture is not "centered" I've made a Regular sculpture for the front and an horizontally inverted for the back.
With new dimensions - now is a square picture to avoid been cuted on the top.
Here goes the wall and the object at the right
***** https://ibb.co/P4H5ZgN
I also found this:
On the render by default, there is NO line on top of the object.
With the YafaRay plug-in the line is there!
And if you zoom the picture you will see that the YafaRay blurs the horizon line.
***** https://ibb.co/2dXW3qg
The YafaRay produces a blured horizon and keeps the stange line on top of the object.
But the image is more sharp.
***** https://ibb.co/hBh1R1r
Let me know something about this, please.
Anyway your help has solved my problem.
Thank you so much.
HAppy easter!
Best regards
