Sweet Home 3D Forum » List all forums » » Forum: Wishlist » » » Thread: Z-offset for texture? » » » » Post: Re: Z-offset for texture? |
Print at Sep 29, 2026, 9:29:42 AM |
| Posted by Puybaret at Mar 29, 2020, 8:09:53 PM |
Re: Z-offset for texture? There's no 3rd dimension for textures shifting. The way a texture image is applied on a surface depends on the texture coordinates defined on a 3D model. Shifting the texture along X and Y allows to shift the image on all the surface of the 3D model (or a wall), but shifting the image and on a part of the model and not on another part is only possible if you change those texture coordinates which is not possible in Sweet Home 3D. A solution for your problem is to use 2 different objects. But if you use walls, shift the texture along Y will work too. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Sep 29, 2026, 9:29:42 AM |
