Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: windows 3D builder » » » » Post: Re: windows 3D builder |
Print at Sep 21, 2026, 11:45:00 PM |
| Posted by Puybaret at Mar 14, 2020, 11:25:56 AM |
Re: windows 3D builder Thanks for your file. The OBJ file can't be read because it doesn't respect the OBJ format specifications. As it's a text format, you can check by yourself: lines starting by "v" are supposed to describe a vertex with the 3 values of its coordinates (and a possible 4th value used as a weight). In the file you sent, "v" lines are followed by 6 values, making it wrong. It will work if you remove the trailing 3 numbers of "v" lines. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Sep 21, 2026, 11:45:00 PM |
