Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: How to provide floor plan parameters in a file » » » » Post: Re: How to provide floor plan parameters in a file |
Print at Oct 1, 2026, 7:59:32 PM |
| Posted by Puybaret at Feb 22, 2020, 9:15:34 AM |
Re: How to provide floor plan parameters in a file Welcome on the forum, Fritzz. If you opened a .sh3d file with a zip utility, you may have noticed it contains a file named ContentDigests too. This text file helps to check the consistency of a .sh3d file at opening time. When you externally change the resources referenced by Home.xml contained in a .sh3d file, you should remove the existing ContentDigests. As it’s optional, you will just lose the consistency check at opening, that’s all! If you want to directly open a XML file without its texture images stored in a .sh3d file, you’ll have to indicate the catalogId and image attributes of its textures from existing values found in the default catalog or in the PluginTexturesCatalog.properties file of other texture libraries. Just pay attention to avoid a leading slash / in the value of the image attribute (like I did in the model and icon attributes of the example I posted last time). ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Oct 1, 2026, 7:59:32 PM |
